To perform a factory reset on the BTR200, first make sure the unit is plugged in and receiving power. Next, hold down the Connect button for ten seconds. The LED should turn solid red when the reset is complete. After performing a factory reset, you will need to repeat the pairing process for any devices that need to be connected to the BTR200.
