[ How-To ] Pairing
Before you can use the BTX270, it will need to be paired to your phone, tablet, or computer. To pair the BTX270, follow the steps below:
  1) Switch the BTX270 on
  2) Hold the multi-function button (square icon) until the LED begins to alternate between red and blue.
iOSAndroidWindowsMacOS
  3) Open the Settings app.
  4) Choose the Bluetooth section of the Settings app.
  5) Tap on the BTX270 in the list of devices that are available to pair.
  4) Choose the Wireless & Networks section of the Settings app.
  5) Choose Bluetooth, and make sure it is turned on.
  6) Choose Scan to scan for pairable devices.
  7) Tap the BTX270 in the list of pairable devices to pair and connect.
  3) Make sure your computer is Bluetooth enabled and has the appropriate drivers installed.
  4) Click the Start button/Windows button and type "Devices and Printers".
  5) Open the Device and Printers program when it appears in the search results.
  6) Choose "Add a Device" at the top of the Devices and Printers program.
  7) When the BTX270 appears in the list of pairable devices, double-click it to pair and connect.
  3) Open the System Preferences program from the dock or the Apple Menu.
  4) Open the Bluetooth section of the Preferences program.
  5) Click the Pair button on the BTX270 when it appears in the list of visible Bluetooth devices.
