Before you can use the BTX450, it will need to be paired to your phone, tablet, or computer. To pair the BTX450, follow the steps below:
1) Power the BTX450 on
2) Press and hold the Bluetooth button until the BTX450 plays a tone
and the LED begins blinking quickly.
iOSAndroidWindowsMacOS
3) Open the Settings app.
4) Choose the Bluetooth section of the Settings app.
5) Tap on the BTX450 in the list of devices that are available
to pair.
4) Choose the Wireless & Networks section of the Settings
app.
5) Choose Bluetooth, and make sure it is turned on.
6) Choose Scan to scan for pairable devices.
7) Tap the BTX450 in the list of pairable devices to pair and
connect.
3) Make sure your computer is Bluetooth enabled and has the appropriate
drivers installed.
4) Click the Start button/Windows button and type "Devices and
Printers".
5) Open the Device and Printers program when it appears in the
search results.
6) Choose "Add a Device" at the top of the Devices and Printers
program.
7) When the BTX450 appears in the list of pairable devices, double-click
it to pair and connect.
3) Open the System Preferences program from the dock or the Apple
Menu.
4) Open the Bluetooth section of the Preferences program.
5) Click the Pair button on the BTX450 when it appears in the
list of visible Bluetooth devices.
5) Tap on the BTX450 in the list of devices that are available to pair.
4) Choose the Wireless & Networks section of the Settings app.
7) Tap the BTX450 in the list of pairable devices to pair and connect.
3) Make sure your computer is Bluetooth enabled and has the appropriate drivers installed.
4) Click the Start button/Windows button and type "Devices and Printers".
5) Open the Device and Printers program when it appears in the search results.
6) Choose "Add a Device" at the top of the Devices and Printers program.
7) When the BTX450 appears in the list of pairable devices, double-click it to pair and connect.
3) Open the System Preferences program from the dock or the Apple Menu.
5) Click the Pair button on the BTX450 when it appears in the list of visible Bluetooth devices.
