There are no drivers that are specific to the BTH410. Like other Bluetooth devices, they are supported by the generic A2DP and HFP drivers for your computer's Bluetooth adapter, which support stereo audio and hands-free audio, respectively.
• If you are using an external USB Bluetooth adapter, the drivers
should be available at the website of the company that manufactured the adapter.
