There are no drivers that are specific to the BTM440. Like other Bluetooth earpieces, it is supported by the generic HFP drivers for your computer's Bluetooth adapter, which provide hands-free audio.
• If you are using an external USB Bluetooth adapter, the drivers
should be available at the website of the company that manufactured the adapter.
