[ Troubleshooting ] Quick Troubleshooting Guide
Goal: Quick fixes for connection, driver, and recognition issues on Windows, macOS, and Linux.
1. General Pairing Steps (All Systems)
If your adapter is recognized but you cannot pair:
  1. Plug in the adapter.
  2. Verify the Bluetooth icon appears (Taskbar on Windows, Menu Bar on Mac).
  3. Put your device in Pairing Mode.
    Try one of the following on the device you are pairing to the BTD600 (headset, mouse, etc.):
    a. With the device off, press and hold the power button for 10 seconds until the light flashes rapidly.
    b. With the device on, press the Bluetooth or Pair button until the light flashes rapidly.
    c. With the device on, press and hold the Bluetooth or Pair button until the light flashes rapidly.
    d. Consult the device manual for instructions for entering Pairing Mode.
  4. Select “Add Device” in your computer’s Bluetooth settings.
  5. Pin Code: If asked, enter 0000 or 1234.
2. Windows Troubleshooting
Issue: Driver errors, “Driver Unavailable,” or conflicts with built-in Bluetooth.
  • Disable Built-in Bluetooth:
    With the BTD600 unplugged:
    1. Right-click Start > Device Manager.
    2. Expand Bluetooth.
    3. Look for “Intel Wireless Bluetooth,” “Realtek,” or “Qualcomm.” Right-click > Disable device.
    4. Power off your computer.
    5. Plug in the BTD600.
    6. Power on the computer.
  • Install Drivers:
    • Windows 10/11: usually installs drivers automatically. If not:
      1. Go to Settings > Update & Security > Windows Update.
      2. Click View optional updates > Driver updates.
      3. Check for “Bluetooth” or “Kinivo” and install.
  • Remove Old Software:
    • Unplug the adapter, then uninstall any “WIDCOMM Bluetooth Software” or third-party Bluetooth suites via Settings > Apps, as they may conflict with Windows 10/11. Reboot and try the adapter again.
  • Check Services:
    1. Press Win + R, type services.msc, hit Enter.
    2. Find Bluetooth Support Service.
    3. Double-click it, set Startup type to Automatic, and click Start.
**3. macOS Troubleshooting **
Issue: Adapter not showing in “System Preferences” or not working.
  • Note: The adapter itself does not appear in the standard Bluetooth menu names; the menu will look the same. You must verify it is active in the System Report.
  • Verify Connection:
    1. Apple Menu > About This Mac > System Report > Bluetooth.
    2. Check the Address (MAC address). Unplug the dongle and refresh; if the address changes, the dongle is working.
  • Force macOS to Use the Dongle (Terminal Command): If the Mac keeps using the internal card:
    1. Open Terminal (Cmd + Space, type “Terminal”).
    2. Paste this command and hit Enter (enter password if prompted): sudo nvram bluetoothHostControllerSwitchBehavior=always
    3. Restart your Mac.
    • To undo this change: sudo nvram -d bluetoothHostControllerSwitchBehavior
4. Audio Drops, Lag, & Range Issues (Interference)
Issue: Choppy audio, mouse lag, or short range.
  1. Use a USB 2.0 Port: USB 3.0 ports (often blue) emit radio interference that kills Bluetooth range. Move the adapter to a USB 2.0 port (often black).
  2. Use a USB Extension Cable: Move the adapter away from the computer case and Wi-Fi antennas. This is the #1 fix for range issues.
  3. Clear Line of Sight: Bluetooth cannot pass through metal (computer cases) or thick desks easily.
  4. Wi-Fi Interference: If possible, switch your Wi-Fi to 5GHz, as Bluetooth shares the 2.4GHz frequency.
