Will the BTD500 work with a gaming controller?
Game console controllers are not designed to be compatible with standard Bluetooth interfaces (such as the BTD-500), and will not work automatically with a PC.
While special software exists that can be used to connect a game console controller to a computer, it requires additional work to set up, can cause problems with the computer’s ability to use Bluetooth normally, and is not supported or recommended.
